Dropped a Cylinder?
https://forums.aussieveedubbers.com/threads/80302/dropped-a-cylinder
RA28GT ·
Hey guys I've recently dropped a cylinder in my EFI 1600 in my fasty.
I was driving on a very hot day and all of a sudden it lost all power and torque. Under basic examination ive found its only running on 3 cylinders now (removing plugs from dizzy, one doesn't make a difference when off!)
Ive got spark at both ends so its not a spark issue, what potentially could i have wrong here? Valve problems? I'm pretty new to dubs and still new to engines in general so if anyone can give me some advice so i could see where I'm headed it would help alot!
yeah pop off the rocker covers and check your valves' clearance and make sure they are all opening and closing - you may have broekn a pushrod or pulled a stud so the rockers can;t push on teh valves properly
If it's EFI, check you're getting power to the injector and/or the injector is working
greedy53 ·
TRY SWAPPING AROUND YOUR SPARK PLUGS SEE IF IT'S A PLUG
71-BEETLE-SEDAN ·
I hope You picked the cylinder up. Was there any damage to it after its fall. Na jokes hope You sort it outg
RA28GT ·
Turned out to be an injector issue!
Hooray nothing internal.
