WTD Qld S/bug steering column housing
https://forums.aussieveedubbers.com/threads/80355/wtd-qld-sbug-steering-column-housing
I'm trying to find a steering column outer housing from a late superbug that has the column mounted indicator switch. Cast into the bottom of the housing are two part numbers, ie SWF HLS 71 (top number) and SAE 08 71 (lower number). The VW number is hard to read as it's painted on and quite worn, but appears to be 111 ??? ? 03 H.
Happy to pay for a good housing, dont need any switches, but the M3 switch mounting screw threads need to be useable.
Thanks in advance
Matt
h ·
hey matt
i not have sorry but..
if you find one down here in melburg i can bring it up in late jan..
let us know..
pauly
Thanks Paul, a neighbour has just found one, by tonight I'll see if it's ok, I'll repost if I need to keep looking.
Thanks for looking
Matt
vwsteve ·
i have a complete s/bug steering column with wheel attached if you need it,cheers
