Subaru ECU pinouts needed
https://forums.aussieveedubbers.com/threads/80513/subaru-ecu-pinouts-needed
crzbug67 ·
hi i am in the process of converting to EJ22 power but the engine and computer i have got are out of a 6/94 model liberty so it has a three yellow plugs at the ECU and i can not for the life of me find anything that matches any help would be greatly appreciated the model number of the ECU is UI 22611 AB640 A18-000 RV2. Thanks
seagull ·
This is a gen 2 liberty . Super cheap , repco have the manual for this
mackaymanx ·
I,ve edited this post to remove the diagrams which are incorrect.
mackaymanx ·
I also have a diagram for a SOHC EJ20 which is also for the 3 plug ECU, it also seems to be right. But I have not got around to comparing it to the above diagrams yet.
crzbug67 ·
Thanks for your replies i will check this out tomorrow i have a manual which is almost right with the color codes but there is no pin outs of the ecu
jzk25 ·
That pinout is not correct for an EJ22 Aus engine. There is also 2 different pinouts and ecu's that will run the same engine in the Gen 2 Liberty so be careful which you use. 94-96 is different to 96-98.
You could always pay $250 and get the wiring stripped, prepped and labelled for you. Connect B+, Ign switch and Starter signal and it'll run. 🙂
mackaymanx ·
Yes I get it you make looms, doesn't help us out finding a pinout thought.
mackaymanx ·
crzbug67 try your local libary, I just found some diagrams there. "EFI and Engine Management" (the are 4 volumns) or the Liberty manual.
jzk25 ·
Merry Christmas. Blame photobucket for them being upside down.
mackaymanx ·
Thanks for that, just had some time to compare it with what I got at the library the other day. Corrects one terminal of I have and fills in all the details that don't get included in the non factory manuals.
Cheers and Merry Christmas
crzbug67 ·
Yea thanks allot this is the best Christmas present i have got this year
mackaymanx ·
Put this in a more readable format, let me know if you find any errors and I will fix them up.
