Open to all suggestions on new/newer front seats to fit a 76 Kombi, preferably with the least amount of modifications (and estimated cost please) 馃檪
Andy 路
Some of the early T3 (square shaped) Kombi seats will slide on your original seat rails and are a bit nicer to sit on than originals.
Check the wreckers for some. Just double check they'll fit before you buy them!
:thumb
KruizinKombi 路
Or alternatively, spend the money with a good upholsterer. They can reshape the seats for more support if needed. 馃檪
KOM123 路
Thanks both for the suggestions 馃檪 Andy, btw, what year models are we talking about when you say early T3s?
Andy 路
Shucks, I knew you'd ask that.
Not entirly sure, but I think it was all the air cooled ones which went to '84 or '85 or there abouts.
Maybe if some T3 owners on the forum can measure the width of the rails for you?
:thumb
kombi69 路
Andy, do you know if the type 3 Kombi seats will also fit a 1969 Kombi? Thanks
baybuscamperkid 路
ive got RX3 buckets in mine. very comfy, small enough. as for mounting, on the drivers side i am bolting on the lower part of a kombi seat and will upolster over it when i redo the upolstery so there is full movement and a stock look. on the passenger side i am using a set of Ford Laser rails as they seem to be the same as the RX3 rails and are completely removable. one side bolts to the seat, one to the wheel arch and an equal height bracket and bingo u have a seat that has full movement and the runners are similar enough to the kombi drivers side ones to look stock.
KOM123 路
Who knows, mebbe there will be some nice seats up for grabs at Valla even 馃檪
