I have just been given a complete 1300 (AB) Dual Port Type 1 Motor.
I currently have a brand new new set of standard 1600 Barrels and Pistons.
Will these Barrels and Pistons bolt straight on to the 1300 motor, or do I have to modify the heads?
Peter
Does the 1300 go??
All the 1300 DP's i have driven go as good if not better than a 1600
Been told it is to do with the small valves and velocity at the valves
I wouldnt be touching it if it is in good condition
rastas4 ·
Apparently it does run.
I have a 1967 Beetle with a tired 1600 Single Port in it. (This is the original case with 1600 Barrels, Pistons and Single Port heads on it.)
Since I got this Dual Port 1300, I thought about giving the 'old girl' a heart transplant and doing the 1600 thing with it??
I would just put the 1300 DP in her
clinker42 ·
Id put the barrels on, an extra 300 is a good increase and use the TP heads.
Matt Ryan ·
Barrel size is different. 1300 tp heads will need to be machined to fit 1600 barrels.
Everything else is the same except barrels and heads (& sometimes, pre-heat tubes). This makes 1300 tp cases good candidates for rebuild as they haven't had to work hard. They have the strength of a 1600 but have only done the work of a 1300.
