Many questions
https://forums.aussieveedubbers.com/threads/80577/many-questions
71-BEETLE-SEDAN ·
Okay, so ive got a 1971 beetle, its a standard and have a few questions.
Firstly i want to change the gear box oil because it hasnt been done in ages. I know ow im going to fill it etc but what with, ive got 3 litres of castrol VMX 80, i dunno if this is the right stuff its just here thats all.And i know i need 2.5 litres of whatever i put in it.
Secondly engine oil, i do my oil every six months, at the moment ive got 15w 40 in it, its a good oil, only thing is the idiot light is begging to come on a bit more while im driving and its got the right amount in it. So this means ive gotta go thincker oil right. What is the next thickest oil i should be using, i know this is a highly controvestial issue i just want to know.
Um this is for the 64, what parts need to be changed for a 12v conversion, like is it everything or just things like the starter, alt/gen etc.
When going to wider rims do i need to beef up my axels, or can they cope.
thats it for now, thanks for the help.
the gearbox oil change isnt hard
get yrself a 17mm hex allen key to undo the 2 drain holes and the filler hole, also a syringe from auto one is good to suck up the new oil and fill in the side hole let it drain for a while and clean off all the metalic particles from the drain plugs with a rag
Try cleaning the idiot light switch, they sometimes clog up. I use Nulon 15w 40 in Davids car, you could maybe go thicker in summer.
You can leave your 6 volt starter.
71-BEETLE-SEDAN ·
Okay. Will clean it up this arvo. I think i will put penrite 15w-40 in it again.
And i am going to get another bug for parts for the 64. Mainly engine etc and am after a list of stuff to get to convert the 64 to 12volt.
Purple Martin ·
for the engine oil: Castrol GTX2 is perfect for aircooled VWs.
for the 6v to 12v conversion:
generator & voltage regulator,
coil,
battery,
all bulbs including the dashboard lights,
flasher relay,
choke.
Will require a ballast resistor for the wiper or new wiper motor or a regulated 6V supply for the wiper motor.
Will require a new fuel level sender or a regulated 6V supply for the fuel level sender.
No need to change starter motor.
I think that's everything! Umm... not sure what to do about the horn.
71-BEETLE-SEDAN ·
Okay, well im pretty much getting a new engine for the 71 so the 64 can have the coil, generator, and carb so thats the choke bit done yeah, and i can get my hands on a battery, and could also get another 70 something bug for the rest of the bits.
Thanks for the list hopefully itll be drivable for the nats.
Purple Martin ·
I've found out that you can leave the 6v horn in place: it only gets used for very short periods so it's not going to overheat from 12v.
p.s. if you have multiple questions you can start a new topic for each one, that way you can give a meaningful topic title for each one, which will help people find the information they are looking for and will help people to help you 🙂
71-BEETLE-SEDAN ·
Okay, thats good because the 6v horn is louder then my 12v one and a only put em in one so i didnt have heaps going at once
