Removing Pedal Assembly
https://forums.aussieveedubbers.com/threads/80640/removing-pedal-assembly
Mildoval56 ·
Hi - I need to remove the entire pedal assembly from my 56 oval (need to replace floor pans). I thought this would be a straight forward job? I have unbolted every bolt I can see and the whole thing is loose. To remove, it appears that I have to take out the shaft that the accelerator pedal is attached too, but on the left side of the tunnel is the arm that attaches to the cable - on the right side of the entire assembly is the accel pedal which appears fixed?? Any help would be much appreciated!
grumble ·
Let the clutch cable adjustment go,remove the 2 bolts on the L/H/S,remove the accelerator cable link,brake push rod,the 2 bolts mounting the cluster and then the pedal cluster should come out with a little jiggling.Sorry forgot to mention to let the clutch cable go on the pedal link in the tunnel.
Mildoval56 ·
Everything is lossened off - it is the acclerator shaft that goes right trough the tunnel that will not come out; is the washer (numbered 59 in diagram) meant to unscrew (after taking off the 10mm nut), then allow the accel pedal to come off first?
http://i197.photobucket.com/albums/aa28/in2vws_com/in2vws/1956%20T1%20Parts/1956_Type_1135.jpg
ian.mezz ·
take the little clip or pin out number 55 or 54???
ian.mezz ·
two bolts under near go pedal
and I think two or four bolts on side of the tunnel ????
Mildoval56 ·
Job done! Thanks for the input. The accel pedal was almost fused onto the removable shaft that goes through the tunnel. With a lot of lubricant and patience this was eventually removed which free the whole assembly.
