I've recently purchased a 1972 S bug which I am now trying to, slowly, fix.
When I purchased it the previous old glove box hat rotted out so I've purchased an aftermarket fibreglass job which seems to fit pretty well. To fit the switch I had to remove the cable from the hood latch at the front. Unfortunately being fully aware that shutting the hood would be a fatal error wasn't enough to stop me doing it out of habit. As soon as I heard the click my heart skipped a beat. Bugger.
Anyway fortunately I hadn't put in the new glove box yet so with a broom stick, some cloth tape and a wire coat hanger I think I may be able to release the latch. Unless anyone has any better ideas?
Anyway what I don't have is an idea what the latch looks like underneath and what I'm feeling for. If someone could take a photo of theirs and upload it I, and my spare tyre would be eternally grateful.
Also the cable was loose, and there are no guides to feed it through, how, and where do I fix the cable so there's enough tension for the latch to be effective. Photo's would say a thousand words here too.
TS
TrentS ·
G'day VWer's,
TS
is the spare tyre in place?
usual method is cut the handle off
i had to get into a mates Sbug with snapped hood cable
it was freshly painted with a custom blend paint so i couldnt do anything drastic like that
ended up removing the crush plate underneath and coming up thro the inspection hole in the spare wheel well
was a blast with the weight of the spare ontop of it but i managed to release the latch from inside
TrentS ·
I had actually removed the spare wheel so I'll give that a go once I can get hold of a ramo, cheers.
try the broom stick or a bit of steel rod or remove the inspection plate
other wise as per above cut the handle and unwind the screw to open the bonnet
get your self a after market new bonnet cable from super cheap or similar and mount down low on the metal bulkhead under the dash somewhere
dont bother trying to re mount in the glove box it will only give you more greif
also get some tie wire and ie around the latch mechanism and put out to the side through mudguard as a sendard cable just in case the other breaks
