Front Callipers
https://forums.aussieveedubbers.com/threads/80808/front-callipers
Newt ·
Hi Gus,
Im currently running front callipers from a 73 Super.
Is there a larger calliper you can run?
Ive heard stuff about Talbot - but dont know much about them.
Newt
colonel mustard ·
Sherman sells a front set that apparently have a larger pad size.. I can't tell you how much bigger though.
I tried to buy some Talbot ones a few years ago, they don't seem to be around anymore.
The biggest piston size early Type 3 at 42 mm as opposed to 40 mm and it uses the twin pin pad that is also used on the 72 Superbug.
colonel mustard ·
Same bolt pattern on the type 3 ones Steve?
They are the same bolt pattern as Type 1 calipers, you can pick them easily because they only have one bleed nipple.
colonel mustard ·
Thanks for the tip Steve. It's on the list. The list is long. Common target, give me a job :P
Um, Is talbot a brand or a car.....? Where have I been, under a rock?
Newt ·
Thanks guys,
Are all twin pin of the 42mm variety? (or are some 40mm)
Newt
colonel mustard ·
as steve said, the super beetles have 40mm twin pins.
cam070 ·
Do the type 3 calipers offer much more stopping power?
It was one of the 1st things I did on David's car when we bought it, I felt that they bit better. I was going to fit Type 3 rear drums as well but then I decided to go rear discs instead.
colonel mustard ·
how much bigger are type 3 drums.... lots of people rave about them....?
cam070 ·
1303Steve wrote:Hi
Would that type of conversion be suitable for a 1916 conversion?
The front callipers just bolt straight on, no adapters or anything. I'm not sure of the increase in size of the Type 3 rear brakes but its quiet large and they work well, CT is using them on the rear of his oval, as have many other VW racers.
I've posted these before but this what the pads look like in various Beetle & Type 3 VW callipers
colonel mustard ·
my calipers are out in the sun with the paint drying. I will post photos with the pads in later this week!
colonel mustard ·
beetle front calipers, two pin, two bleeder...
pads
hope that explains... something.
