Hi all,
I'm building my 1776...again...and will do so until I get it right!
Concerned about the backlash between the steel straight cut gears and also the oil pump drive off the cam.
It is an AS41 german case but it HAS been line bored by hellbug's old machinist 0.5mm undersize on the back of the crank bearings.
It has been running but there is definitely more engine noise than there should be and I think one of these is the culprit. Kinda of a clacky sound when idling but everything else should be fine as it's all new.
Am running aftermarket cam too.
This can't be right!
Gears, cam and hi rev valve springs were bought new from CB performance.
Oil pump is an anodised tooleys 26mm replacement pump.
http://www.youtube.com/watch?v=LxOmulQMWKo
Any ideas from experienced people??
More info needed? Let me know!
Toby
type3lover ·
