Spindles
https://forums.aussieveedubbers.com/threads/80876/spindles
71-BEETLE-SEDAN ·
Can i install drop spindles on my 71 without narrowing my beam and how no rubbing issues.
'Clearance'and how much depends on wheels and tyres used.
71-BEETLE-SEDAN ·
Weill ive got 195/65r15s
but what offset and rim width are your wheels??
71-BEETLE-SEDAN ·
They dont have an offset stamped on them and they are 4.5 inch but i do have a set of rims that are et41
vwo60 ·
Hi, i have a set of dropped spindles on a 69 karman convertable, if you get the right set there is no increase in the track, the wheels on the front are a set of porsche boxters that are 16" x 6" with a 55 et and 195/55/16 toyo's, the only problem was a small decrease in the turning circle with the tyre touching the trailing arms, i think that the 195's are the largest that i can run on the front with standard guards, the et 41 should work ok
71-BEETLE-SEDAN ·
okay, good to hear, will be getting a set monday
zayus ·
Hello,
How did you go with your drop spindles?
What size tyre did you end up running?
