not much in the way of garages or wrecking yards to reference this type of stuff over here and I am a long way from my bug back home.
this is for the t1 box and t4 engine. should be coming together shortly as I have some time off work
dangerous ·
M10x1.5 pitch.
Case should have studs, so you will just need matching nuts and washers.
Top will need a bolt, nut and some washers.
RHS is longer since it passes through the starter as well.
shaihulud ·
Because you will be bolting up aluminium, make sure that you use big fat flat washers. Lock washers are not usually used.
Golde60 ·
thanks guys
The top bolts are 70 and 110 mm long for type 1 and type IV.
