i need some help, i replaced the horn on my squareback, now when i indicate right the horn toots aswell as the indicator flashing and if i push a bit of weight onto the steering wheel the horn aslo toots, can anybody help me to fix this problem as i get a fair bit of abuse every time i turn right
is it a stock steering wheel or sports one?
i had a similar problem years ago after putting a sports wheel in one of my bugs
except it was flashing the highbeams instead of beeping the horn
the gap between the steering wheel and the column was too small causing pressure on somehting as i turned
the column mounts are slotted so u can loosen the bolts off and slide it down for a bigger air gap
nishii77 ·
stock wheel i'll have to have a go at it in the morning when i've got some light
thanks
