jjwebb123 wrote:Hi Guys.
Just wondering how many of you guys have electronic dizzy's on your beetles.And if you think they are a good thing,is there any performances advantages and so on.Also do you recommend an electronic coil to match it.So like buy everything thing at once dizzy,coil, leads.
Any ideas and thoughts would be good.
Easier starting is the main advantage... first kick every time...
I have been using a home made kit - a High energy ignition that uses the normal coil [not GT40] and points...
the points never wear out, but the rubbing block does...
the points I was using, had a plastic rubbing block, and it wore down and shorted out.. killing My High Energy Ignition..
so, Now i'm back to a condensor again.. lol
I have bought a New SVDA Bosch dizzy and Pertronix ignition system from aircooled.net in the USA...
this dizzy gives better mileage and the engine will run cooler...
I haven't gotten around to putting it in as yet.. as I have a few other things to do to My beetle... lol
it is recommended that the Pertronics is used with a Coil over 2 ohms.. 3 ohms is better..
most performance coils are under 1 ohm... and will burn the inductor out.... instantly..
You can use a new set of wire ignition leads with VW resistor ends with the air seals.. these are very inexpensive.. [$40]
or You can spend $200 on a performance set of leads...
which will do the same thing... lol IMHO...
