Well, after owning it for 25 years, having it registered for the first couple, I finally pulled KO813 apart for some restoration work. None of you will be surprised to hear that there was more rust than could be seen from the outside, but not more than I expected. Many broken off bolts etc. Most of the rusty stuff can be bought. Any enlightened advice on where to get the rust panels from? I'll keep you all posted.
ztnoo ·
Tony,
Congratulations on the start of the resto of your CB.
It does look like you are in for a lot of work, but still have something to work from and not its not a total rust basket case.
We've all seen cbjohn's skilled work.
I'm sure he could supply you with any panels you might need to bring your CB back to its former glory. Just a suggestion....
Keep us all informed and keep posting pics too! 👍
Regards,
p.s. That's a really nifty one wheel dolly you have attached to the pan horns......great idea for moving the chassis around without rear wheels. 👍
bevoracing ·
Thanks Steve.
You like my "really nifty one wheel dolly" eh? It's not a new idea, you see them around from time to time. Have a look at the Obsolete Air-Cooled Documentation Project at http://oacdp.org/ There’s a workshop tools document there, have a look at tool VW676, that’s the official drawing, I just made mine from crap I had lying around, worth every bit of effort too. I’ll be making something for the front too for when the beam comes out. Not enough room in my shed so I have to roll it around as I work on it.
I see those people who work on those little squeaky cars with the 3 wrongs have started using similar things for when they remove rear suspensions or front assemblies, the technology carries on. The 3 wrongs?? Engine in the wrong end, the wrong way around & driving the wrong wheels. You know the ones.
Tony 🙅
58camper ·
Tony,
Good to see the Ute is getting some resto work done,. You hit the nail on the head talking about how much work there really is when you pull it apart. I know several people over the years who were so dissappointed at the level of rust and panel work they could/did not see when the car was assembled that they put the car back together and sold it on. They could not handle the effort.
Yes, you should talk with Johnny Nofingers ( CBJohn) as it might be surprising what new fabricated panels he has lying around his workshop.
As Steve says, keep us informed of the progress.
countrybuggybill
ztnoo ·
Tony,
Thanks for the link, that's a very informative site.
I found the drawing of the wheel dolly......looks like some Yank converted some of the fabrication dimensions.
Imagine that!
bevoracing ·
Here you go Steve, this is how you make the one for the front. I’ll make another set of those small packers at the top, put them on the other side at the bottom and it can be turned around and mounted upside down, if you want the chassis up the other way. Those wheels are of my daughter’s scooter, she grew out of it, and so did I.
I went over that nose with a chipping hammer after the photo was taken, it looks OK there but it’s a write off. Ah, the hidden joys of oxidisation.
Dilbert ·
it seems like more time could have been spent drawing that little wheel than it would take to actually make one. nice looking car 🙂
BUGBOY ·
All the parts you have shown with the rust are all from a 60's beetle. You can buy all those parts new.
Your heater channels you can replace just the bottoms if they are just rusted there.
cb john ·
Nathan, nothing on the CB is rust free...😁
bevoracing ·
You’re not wrong there John. They were only painted in the places you can see. The “tar” that it was calked up with has dried out and fallen off in most places. It did spend about 10 years as a rain gauge so I guess that’s what you get. I’m having another chassis coming around this afternoon to apply for the job, we’ll see.
You’re right too of course Nathan. I see the side channels advertised on one US site as “economy” with no heater tubes installed, that would be nice, save having to “repair” the new ones. I see the bottoms are available, unfortunately the top sections aren’t much chop either. I’ll see what’s best. Do you know who keeps rust panel stock in Australia?
The actual country buggy parts aren’t as bad. Side pod bottom panel on the right is gone. Bonnet and engine cover have rust around the rolled edges, the rear panel below the engine lid is bubbled, all pretty normal I guess. We may need to talk John. Chassis first.
Any comment on rust panel stock in Australia would be appreciated? Comments on floor pan metal thickness, the original is 1mm, what are some of these aftermarket ones, does anyone have experience?
Cheers Tony
cb john ·
Tony, original floor panels were 1.3 - 1.4 mm thick...now they don't make them the way they used to. Aftermarket replacement panels and rust repair section are barely 0.9 mm. Quality of metals used is dubious, can tell by the way they weld..Since commercially available thickness of sheet metal in Au. is
0.55, 0.75, 0.95, 1.15, 1.45, 1.95...it is impossible to find the correct gauge ... forming / drawing properties are probably reduced to less than a half...
