have a 67 ts fastback pretty much pulled apart but most parts are there except hood lining , shell is very good for a type3 only minor rust bits hence the $$$.
i also have popouts and either a 1600 twin port motor (needs 1 guide re-fitted) or twin carb 1500 single port.
can fit either irs and late model type3 box or swing with small 4 or wide 5.
Have full set of orig wide 5 rims and hubcaps wrap around ind and reflectors and lowbacks which could use a retrim .
pan is a rust free 72 with the early slide mounts supplied .
klaus 0428 427 986 $1000 ono wollongong
CUTTING UP LET ME KNOW IF YOU NEED PARTS OR SHEET METAL. ALSO 64 NOTCH AND HEAPS OF LATE PARTS.
Klaus ·
