methonol mucher
https://forums.aussieveedubbers.com/threads/81168/methonol-mucher
stalker 路
my bum blister 74 mm scat forged crank, 92mm mahle forged pistons, dry sump pump, vertex mag, hilbourne mechanical fuel injection, double d ported heads to the max, modified chev valves to suite, 1:45:1 ratio rockers, the cam is a custom grind to suit ,, cant tell, makes about 200 hp , revs to 8 grand , custom made flywheel using Porsche clutch plate and pressure plate on a modified vw flywheel weighs about 3 pouds and about 5 pounds bolted together , ring gear is bolted to the pressure plate , runs on methanol and i get 2 kays a liter , has custom made dog box made from plastic , it will soon grace a 68 beetle modified to run pump gas ..i wanna run 11s on the quarter,,,馃シ
VWFREAK 路
Ooses potential 馃憤
stalker 路
its a runner it was rebuilt 4 years ago and sat in the corner of my shed ,, now the misses beetle looks good to put it in .. should be going in about 4 days,, ill post a pic of the beetle ,, i custom made the studs to fit commodore wheels ,,
