Aussieveedubbers 路 Bugs
how to fix fuel pump pipe?
https://forums.aussieveedubbers.com/threads/81242/how-to-fix-fuel-pump-pipe
jjwebb123 路
Hello people.馃槉
Um the other day when we took the engine out of my 1970 beetle,we noticed that the pipe on the side of the fuel pump,(in which the fuel line slides over) popped out of the fuel pump.i think it is the inlet but im tired and its late 馃お
I was wondering as to what glue or technique we should be using to ensure that it stays back in the pump and that it does not leak.As it would be a major fire hazard. I will try to post pictures when i get time.
Sides 路
If it was my car, I'd be using the technique called "buy a new fuel pump".
The fitting popping out like that is a pretty common thing, and a new fuel pump won't cost much.... definitely a much safer option than trying to fix an old one.
馃憤
Also since it's a related topic - fuel filters inside the engine bay are a bad idea, and always carry a fire extinguisher.
jjwebb123 路
LOL oh really i like that technique seems really affective.lol .Yeah i dont have a fuel filter in the back and i carry a fire extinguisher.
Matt Ryan 路
check this post:
http://forums.aussieveedubbers.com/viewtopic.php?tid=80600&page=1#pid750340
Regards,
Matt.
jjwebb123 路
thanks mate thats great.cheers
colonel mustard 路
buy a new pump.
you would need to carry a fairly big fire extingisher to put out an engine fire...
im not aware of any "glue" that would withstand the effects of petrol, short or long term.
would you rather spend $100-200 (a crazy maximum) on a new pump + fuel lines and clamps, or $1000 for new paint and many other things that would burn like this...
http://images.thesamba.com/vw/gallery/pix/564072.jpg
http://images.thesamba.com/vw/gallery/pix/564071.jpg
jjwebb123 路
yeah i know.i have seen pictures like that before,gives me goosebumps.I didnt think a fuel pump would be that dear lol.
thanks
djnee 路
colonel mustard wrote:you would need to carry a fairly big fire extingisher to put out an engine fire...
Depends how desperate you are to put it out i reckon...and how soon you catch it.
I put out an engine fire in my 69 kombi with a t shirt once...not that i'd recommend it of course!
djnee 路
jjwebb123 wrote:I didnt think a fuel pump would be that dear lol
Yeah, it's a total downer when there's basic stuff that you're expecting to cost peanuts that then turns out to be stupid amounts of cash 馃檨
jjwebb123 路
Waiting on price for fuel pump from micks motors,will let you know how much it cost me.
thanks for your help 馃槑
colonel mustard 路
Don't forget the plastic block and The correct pushrod.
jjwebb123 路
ummm plastic block,pushrod? sorry mate dont quite know what your talking about.lol sorry 馃槀
Sides 路
There's a plastic block that sits between the fuel pump and the crank case, and the push rod runs from the fuel pump down through the plastic block into the case.
The plastic block's can become brittle and crack, break etc.
With the pushrod there's a couple of different lengths, and you really want one that suits your new pump.
jjwebb123 路
Yeah ok,i know what the block is,but im not quite sure what im to do about the pushrod.Do i need to get a new one,or does the new fuel pump have to fit the size of my pushrod.
also i have a 1500 beetle.standard everything.which one of these would best suit do you think.?
FUEL PUMP 17,18,2LTR
FUEL PUMP 40HP -1600 W/OUT ALTERNATOR TYP1/2/3 HORIZONTAL
FUEL PUMP 40HP - 1600 214 131 GENERATOR
FUEL PUMP 12-1600 CHROME
FUEL PUMP T1 1600 ALTERN. 20255
FUEL PUMP 1600 WITH GENERATOR
FUEL FILTER 2.5TDI CRAFTER W/ALTERNATOR
Thanks for your help.
Joel 路
colonel mustard wrote:im not aware of any "glue" that would withstand the effects of petrol, short or long term.
its called loctite and its good shit
Sherbie 路
I have read on here a few times that removing the fuel filter is the way to go...Why is this?
jjwebb123 路
fuel filters in the engine compartment,can be one of the causes for engine fires.The others being, leaking carby or old fuel pump pipe like what i am experiencing. In line fuel filters are better off in the front compartment in my opinion.
Sides 路
Where'd you get that list from - you definitely don't want the last one - fuel filter for a Crafter !!!
馃槀
If you've still got a generator, any of the ones that say "generator" or "w/out alternator" would do the trick. Pretty sure it's the alternator ones that used a different push rod... maybe some one else can say for definite...
Also suspect that the second last one "1600 with generator" is the later pressed metal style... if it is then it'd get my vote.
If the list is from a Volksy place just give 'em a call and explain. Better yet if they're local go in and take your old pump and pushrod with you... then you're guaranteed to get the right one !!!
馃憤
Sherbie 路
Thanks for the info..Hubby is setting about removing the fuel filter now & moving it to the front.
jjwebb123 路
i pulled my fuel pump out today,the pushrod is in really good condition it is 108mm and the intermediate flange is good too.But there was no top or lower gasket
just a bead of sealant around the edges.Lucky im getting a new pump.
levetto 路
I was just wondering, do you recomend to put instead of the OEM fuel pump, and electrical...
Because I just started to have problems with my fuel pump :S
jjwebb123 路
it really depends what you want.i personally have not heard much about electrical fuel pumps,empi fuel pumps seem fine to me, sealed units.
i have one coming in the mail at the moment.
