Extra Oil capacity
https://forums.aussieveedubbers.com/threads/81302/extra-oil-capacity
clinker42 ·
Hi guys
Is it worth putting an extender sump and pick and increasing the oil capacity.
depends where u live and what yr doing with the car
greedy53 ·
WELL I fitt6ed an half lit to me blown kombiy never had any heaating problems and it drove it along the hay planes towing a traler on a oil change it took nearly 5 liters
alien8 ·
I just fitted a full flow oil filter with 1/2 lines and it increased the oil capacity from 2.5 litres to 4 litres. Killed two birds with one stone, more oil and filtered.
My engine does not run any cooler. It just takes longer to come up to temp.
BiX ·
If its standard.... maybe. The extra filter would probably be better. If you drive "spirited" I would go a extended sump, helps stop oil surge, extra oil and helps a little with cooling.
Phil74Camper ·
Unless you buy an expensive but well made Gene Berg one for a high-performance engine, the answer is NO. Read Bob Hoover's article on deep sumps at:
http://bobhooversblog.blogspot.com/2006_11_29_archive.html
hellbugged ·
not necessary until you have a modified engine
takis ·
Unless you drive like hoon?Small sump aid in sloshing in tight turns.
Full flow it and get the benefits of a clean engine.
This will give you a little more capacity in oil and longer life in the motor , otherwise leave it as is.
