What are the best heater channel replacement sections to use.
I see there are Brazil and a Demark type/and most likely others.
How do they compare in regards to fit/quality.
Are they the same in thickness.
Does it matter which is used, or just up to the individual.
They ALL FIT just depends on how much fiddling u do
Most replacement panels are a sort of copy so pushing shoving n grinding is required
The Danish panels are much more thicker than the Brazilian so use if u can get
Kuchster ·
I used the denmark ones, quite a bit of modification necessary to fit them, and still quite different to originals, but once they are covered with the carpet, seats, etc, you dont see them anymore anyway!
