oil stand baffle?
https://forums.aussieveedubbers.com/threads/81394/oil-stand-baffle
sgetty ·
hi all
just wondering which was the proper direction for the baffle that sits under the alt/gen stand?
never had one there
deon
Phil74Camper ·
The baffles face down, so the top of it is flat. The centre baffle is longer, and 'points' towards the rear of the car - that is, towards the fanbelt pulley end, and away from the flywheel.
There should be a paper gasket between crankcase and baffle, and another between baffle and generator stand.
From memory the baffles and gaskets included in a normal engine rebuilt kit. It's hard to imagine why anyone would leave it out in a rebuild - wouldn't
sgetty ·
yeah dont know why, but it will be on there soon
do you mean this side to fanbelt pulley?
thanks for the quick reply man! thats excellent
The louvers need to face down and the open side to the right hand side of the car
looking at the pic above if ur looking down on the engine from the pulley end there facing the right way
this stops the crank throwing oil up through the slots which ends up dripping out the filler
sealant works much better than the crappy gaskets that come in most kits nowadays
I use two, one upside down above the other. This helps to stop oil going up there during BIG revs and during hard cornering.
sgetty ·
thanks heaps dudes
