Broken thread on one of 6 sump plate screws
https://forums.aussieveedubbers.com/threads/81434/broken-thread-on-one-of-6-sump-plate-screws
bus914 ·
How do you fix it?
1500S ·
Helicoil (Recoil) or get a stepped stud made and tap oversize. Suggest M7 x 1 for oversize as 6mm is tapping size for this M7.
DH
stepped studs are available for just that...
at most VW advertised shops...
I have seen them when watching a friend doing an oil change..
I have never had any problems...
You need a T driver [1/4 inch] and socket...
then its hard to over tighten...
and always use a new gasket kit each oil change...
1500S wrote:Helicoil (Recoil) or get a stepped stud made and tap oversize. Suggest M7 x 1 for oversize as 6mm is tapping size for this M7.
DH
M7 bolts and nuts are hard to find .. lol..
My auto gearbox bottom plate has 7mm screws and some have 7mm bolts...
I was going to replace them as I usually replace all old bolts and screws.. but 7mm.. none about...
Stepped stud, M8 one end and M6 the other. I have em. About 5 bucks if you want one.
dangerous ·
For reference, most trans nose cones on bug and bus use 7mm fasteners.
Handy to know if you ever need a nut, stud or bolt,(bolts from mid 1975).
Some type 4 engines used them to hold the clutch cover to the FW.
And all Type IV rocker nuts and studs
