after lowering back looks good but drives shoking wheels look to bent and no suspention hasnt got cut out spring plates can any one recomend to fix it or set it up propley with out geting ripped off ive seen heaps of vws but this one doesnt look right ive lowered it 2 notches i did this my self i need a vw gourou
waveman1500 ·
Sounds like you've lowered it too much! Raise it one notch each side and see if it's any better. Photos might help with the remote diagnosis though, it's kind of hard to help on tech problems with just a short description.
jsheppard64 ·
I'm not a guru... but i lowered the back of my super
2 notches is too far. sat on the rubber bump stop, not nice.
put it back to original and then one side is higher than the other [ one side is about the height i wanted ]
so the higher side.. i turned the higher side down 2 notches in side 3 notches outside.
someone probably will give you a link to the lowering thread on here anyway. Otherwise you can search for it
or you could get one of those coil overs adjustable shocks from place like volks conversion. [they made my back stiffer]
here is the table
You could try Pete Klaack at Level 51 but he is pretty busy
ah lowered swingaxles gotta love em 😂
ian.mezz ·
yeah they look cool but shit to drive 🙅
, you cant have your cake and eat it toooo🤪
