Can someone tell me where to get one????
https://forums.aussieveedubbers.com/threads/81569/can-someone-tell-me-where-to-get-one
Ampdub ·
I was at the action day and happened accross a linkage that i need but i have had a search and can not find it anywhere, maybe im looking in the wrong place. If its your car or know them please could you let me know how i can get my hands on one. It needs to go behind the shroud.
hellbugged ·
That would be a modified CB performance "hex bar"......... extended arm links and air filter bases flipped form one side to the other
Ampdub ·
The arms he used look to be manufactured that way, is there a kit from CB that i could get a hold of. Otherwise I will have to look at twin pull cable linkage kits.
hellbugged ·
Oooooooooo, it's a PHANTOM linkage..........🤓
http://www.cbperformance.com/catalog.asp?ProductID=1260
ian.mezz ·
try Vintage veedub Sydney I think they fitted the A/c
Wouldnt those long arms flex??
What if you flipped the carbs around (http://www.cbperformance.com/catalog.asp?ProductID=501) so as the arms were short.
Adjusting the droop ros the first time would be a bitch but with the filters off would be doable??
works well
amazeer ·
wouldnt most applications where you would be wanting that linkage be using the doghouse cooler?
Ampdub ·
Excellent, Thank you for the directions.
As to the cooler I will probably run an external with this linkage.
