Hey guys.
So I have a 68 swingaxle bug and my dream is to drop/lift a subaru engine into it. From what i've read a 2.2 SOHC is the best fit. (Correct me if im wrong.)
Will this engine (Or any engine) be able to fit under the hood with very minimal cutting to the bay?
Is it realistic to think about converting over to IRS? (Once again i've read that IRS is much easier to deal with.)
Can good heat be achieved with a subaru?
Thanks a bunch for any answers/advice you can give.
ian.mezz 路
well why worry about minimal cutting to the bay.
After all your going to have a great big hole in the front of your vw for the radiator.
I didn't waste time on going the nanny 2.2 subaru, I believe if your going to Mod your vw you ll miles go Turbo馃槀馃槀馃槀
this is heads up racing and the two beetles have wrx motors and stock VW gearbox, the brown & orange coloured one is a 1300 swing axle.with 215HP going through it.馃お
Green & white is a super
click on link below
ps Young Joel will tell you different馃槀馃檯馃槀
Joel 路
bah dont listen to him, he's got a turbo and still drives like an old women 馃槀
All the SOHC motors except EJ25 will fit with no cutting to the body, only a bit of trimming to the valance where the seal channel is
see my thread for exactly what, although ive since cut right out the seal section when i repainted my engine bay for a cleaner look
an IRS conversion is a pretty huge undertaking,
if your going a DOHC motor then u need to move the gearbox forward to keep it under the bodywork which can only be done with IRS but if your happy enough with your swing axle now and your going for a SOHC engine why go through all the hassel of pulling the body off,
that will only show up more work which needs doing
