FS in WA: MSD 5462 BTM IGNITION CONTROL ***SOLD***
https://forums.aussieveedubbers.com/threads/81579/fs-in-wa-msd-5462-btm-ignition-control-sold
humpty ·
Forsale:
Price:
$270 ONO
Where:
Bicton (East Freo)
Contact:
Humpty on 0439 916 076
Description:
From the MSD website:
http://www.msdignition.com/product.aspx?id=4549&terms=BTM
"The Universal Boost Timing Master allows you to adjust the ignition timing in relation to the boost pressure, plus it has a built-in inductive ignition. You can adjust the dash mounted control knob to retard the timing 1° - 3° per pound of boost, up to 15°. You can also set a boost pressure point to start the retard. The increased spark output of the BTM helps burn the fuel mixture more efficiently resulting in more power - a definite advantage when boost pressure is increasing. The Universal BTM is designed to work with most single coil factory or aftermarket ignition amplifiers and points-type distributors."
