inlet manifold pictures added
https://forums.aussieveedubbers.com/threads/81585/inlet-manifold-pictures-added
matt ·
how many different sp inlet manifolds are there?????
matt
4 types 36hp 40hp 1300 1500 in type 1 engines
then theres Type 3 1500 single carby and 15/1600 single port twin carbies
matt ·
thanks mate, would you happen to now which 1 makes the carby sit higher? the 1 i have at the moment makes the accelerator pump hit the generator.
matt
Hi Matthew
I have a 1500 single port manifold which may be the one You need... depending on what engine You have..
the ends of the manifolds are not adjustable...
unless You cut one end and place a rubber hose over the join..
I also presume the hole size at the inlet side would also be different sizes too..??
and the carburetor holes/inlet at the top would also be different for each carburetor size... PICT 28-30-31-32
best of luck
matt ·
here are to pictures to discribe what i am on about. in picture 1 there are spacers between the carby and manifold to make the carby (accelerator pump) clear the generator. picture 2 has no spacers (just a thick gasket) and clears the generator. both motors are 1500sp. my question is why are they different and does any1 have a "bigger" manifold laying around so i can get rid of the spacers????
matt
pod ·
is that one off a type 3 ???
matt ·
as far as i know they are both type 1's, thats what they are on anyway😀
matt
pod, single carb type3s were sidedraft so way different to a bug manifold
Matt, the problem you have is cos the cars been converted to 12 volt.
the 6 volt gennys are smaller in diameter than 12volts
is it a 40hp manifold or 1300?
the difference is easy to pic
matt ·
they are both the same as the single port (1300-1600) in your picture
matt
i guess its possible that one is off a 6 volt 1300 and the other is 12volt 1500
the mounting flange on the 12 volt ones may be across alittle further to clear the bigger genny cos the rest is all the same
dangerous ·
1300 is different to 1500...larger tube too on 1500 from memory.
Plenty of info on it in "How to Hotrod VW Engines".
