Beerboy ·
I have some panels that I need to stick together, which I think are plastic or fiberglass, not too sure, Whats good to join these together. thanks
https://forums.aussieveedubbers.com/threads/81625/joining-fiberglass
Beerboy ·
Smiley ·
barls ·
Beerboy ·
barls ·
57 oval ·
Beerboy ·
thanks mate stupid question but I am not that sure what resin is, where will I get that?57 oval wrote:Scruff the surfaces up with rough sand paper, wipe with acetone to get rid of the wax off of the old fiberglass, then mix a small batch of resin and use it as a glue, clamp the two bits together if possible or put some plastic over the area and sit a weight on it until it dries. the plastic stops the weight sticking to the job. Once dry miix some more resin and add a little talc powder and make a mixture much the consistancy of bog, again sruff the surface and wipe with acetone and apply the filler to cover any join marks or imperfections, let it dry sand back and you shouldnt be able to see the join..
57 oval ·
