Got a bunch of stuff here that will be going to the tip in about a weeks time, if anyone wants anything in the pics feel free to come and pick up from Mt Kembla (near wollongong nsw)
Owen
0413 266 808
ill make up a list of whats what over the next few hours...
SuperOwen ·
Top Pic- Drum Brake Spindles
60's model distributor vacuum only?, unknown new dist cap - GONE
1302 sway bar
Misc Tinware, pulleys etc
Turbo's Gone
New Beetle Fog light lenses.
30 pict something carb
A few stock rocker shafts
Stock dished cam
Old external oil cooler
Bottom Pic- 1302 3 bolt struts and springs
Various cyl heads, pair of single port 1500, pair of dp 1600, pair of waterboxer 1.9
Waterboxer injection manifolds
and anything else you can see in the pics.........
All going to the tip in a week or two if nobody wants anything, nothings in amazing condition, but the carb and feul pumps came off running engines, the turbos should be ok, etc etc.
71-BEETLE-SEDAN ·
Shotty the dist, one of the turbos.
I go down to wollonggong a fair bit and will probably be going down on the 13th do you think you could hang on too those two until then,
Cheers JOsh
SuperOwen ·
No prob sticking stuff in the corner for a couple of weeks. Basically all this stuff is at my parents house which is being sold, hence the big clean out. Just give me a ring and I can put anything aside for a short while.
gavin ·
Hi do you still have the steering wheels and the rings if you do would you post then at my cost
thank you gav
SuperOwen ·
Sorry, pick up only for all this stuff.
71-BEETLE-SEDAN ·
You mentioned one of the turbos is air cooled do you know if it would work on an air cooled db?
SuperOwen ·
Air cooled as in air cooled core, ie no water jackets. Ive had the thing for years and from memory I asked fred? at turbologic about running it on a 1776 years ago and he thought it would work fine. Cant remember the exact specs and im feeling too lazy to go back to the garage tonight, I'll look tomorrow.
71-BEETLE-SEDAN ·
Okay thats even better could i have that one, and will definatly be heading down on the 13th.
Flintstones ·
Owen,
I'll take the injection setup.
Josh,
Can I work out something with you as i won't have the time to make it to the gong any time soon.
I'll PM.
Cheers All
D
tazkralc ·
Whats left. I would like steering wheels, turbos, disc brake spindles(if there drop spindles), remote oil cooler, etc and anything else that would pack around it, in a box.
Thanks Chris
SuperOwen ·
Steering wheels gone, kkk turbo left only, spindles stock drum brake. Dont forget pick up only.
71-BEETLE-SEDAN ·
Hey Owen, turns out ill be down on the sixth now instead of the 13th. Is that stilll all good.
And ill take the carb and the camshaft if thats all good.
SuperOwen ·
6th is fine. Ill put the bits aside.
fish26 ·
I'll come to pick up the kkk and a couple sets heads if still there, thanks
Thinker ·
have you still got the heads sp 1500 & dp 1600.
i can pick-pu on the 30-1-10 am or pm
thanks
bushed ·
could i beg the new beetlefog lights x 2 and the eng lid spring pleeeeeeeeese
pls click my email add ure addy and I will post u a pre addressed prepaid 3Kg postage bag
i will do all the writing and even llick the stamp if i have to... he he
I am too far away to pick up inQld.
SuperOwen ·
Thinker- fish26 put dibs on the heads but not sure which ones so better wait and see what he wants.
Bushed- the fog lights are actually off the european model I remembered, so there on the wrong sides of the car. If you still want them let me know. Eng lid spring gone already.
If anyone wants to pick up bits next weekend is easiest for me.
Thinker ·
i willl keep and eye on the topic and keep my fingers crossed
thanks
71-BEETLE-SEDAN ·
Hey ill be down on the 6th, ill give you a call when im leaving here give you about an hour and to organise place to pick up, chers
Thinker ·
any news on the heads
bushed ·
thanx for the pm's but will check it all later ...don't hold for me as I am rthr busy. taa for your generosity
B
SuperOwen ·
Dual port heads taken. The other heads in the pile are ols wbx heads and single ports. Not really good for much.
Thinker ·
thats ok i am after a set of sp heads for my 1500 so i can reco them the do a head change over a week end.
SuperOwen ·
Your welcome to grab the sp's then. From memory there not cracked.
