1976 VW wrecking
https://forums.aussieveedubbers.com/threads/81687/1976-vw-wrecking
Glenn
Newcastle area NSW
Call 0411 274 155
Wrecking 1976 VW. Stripped for spares but some parts remaining
SSP 3.8 gearbox - great condition: test drive in car (if you are quick!) $300 SOLD
4x '76 wheels (4.5inch and special 37P offset) and worn tyres. Need paint: $40 the lot
1600TP engine complete with tin, clutch and rare 34carby (except alternartor and stand) runs with good oil pressure, no leaks but one pot is lazy so suitable for rebuild: SALE WITHDRAWN - I'LL MAKE IT A 1916!
Good emissions-spec fuel tank: $40
Complete wiring harness cut from car, 1976 two-switch steering column, ig switch, key and door handles (matching set), 2-speed blower/vent unit. All there except tail light pigtails: $150
Front seats (3-point mount) good for frames/bases only for fitting aftermarket seats: $40 pr. SOLD
Rear seat: no sun damage but most of the hair has fallen out; put this vinyl on another seat: $20
Other VW parts available - call and ask!
DylanTheDubber ·
OHH NO NOT ANOTHER 76 BUG GETTING PARTED OUT NOOOOOOOO.
type3disease ·
"Styripped"
like a horse...?
greedy53 ·
i need the head light and blinker relay i think there the same as a bus if ya have 1 post cod
thanks
if u have pm m e
nicolasw ·
hey mate what do you mean by one pot is lazy?
One pot (piston) isn't working as it should - without doing a full diagnosis, it is suffering a dud spark plug, loss of compression or burnt valve
If this is getting parted out, will you strip out the wiring loom or some of it? I am interested wiper and steering column wiring, but could be persuaded in the whole lot.
wow noones asked for the bumper yet 😂
matt if you have no joy i think ive got a 74-76 column with all the switches and looms for wiper/indicator and ignition
DylanTheDubber ·
I would have asked already but am broke the time being lol. from Dylan
beetleboyjeff ·
It hasn't got a rack & pinion has it? if so, I am interested.
Glen
Whats the chassis like ???
Matt, I can strip the harness (complete - I will cut the shell rather than the loom) and sell with the steering column and door locks if you wish. The wiring has been 'cut and shut' sometime in the past to fit an ignition keypad thingo and has a few extra wires for radios etc but apart from that it should come up well - one of the reasons I bought this car was to use the wring but the fusebox doesn't fit mine. Mail order? Might be best to call me...
Jeff, no R&P as it's a flat-screen;
Dave, chassis is rooted. I may consider fixing it for another project if the $ don't add up too far, otherwise it's scrap
it would be OK if the pans are buggared
funbug ·
Do you still have the front bumper? If so, is it original and rust free? If so, I am interested.
ttriebler ·
If the chassis is buggered can I have the frame horns and rear torsion out of it to build a gearbox demo stand?
VWCOOL wrote:Matt, I can strip the harness (complete - I will cut the shell rather than the loom) and sell with the steering column and door locks if you wish.
All I need is the wiper and indicator plugs that go into the column. It'd be nice to have the associated wires too. It would make the instalation easier of the late column I already have. Might be able to use Joels if he has bits already cut up, save your wiring to keep it with the column & keys etc..
cam070 ·
Have you got a 2 speed air switch? If so dibs on that.
And what condition are the headlight surrounds in?
funbug wrote:Do you still have the front bumper? If so, is it original and rust free? If so, I am interested.
Yes and....no
cam070 wrote:Have you got a 2 speed air switch? If so dibs on that.
No it is damaged sorry and rims are gone
ttriebler ·
Well? Any chance I could have the frame horns and torsion out of the wrecked pan?
ttriebler wrote:If the chassis is buggered can I have the frame horns and rear torsion out of it to build a gearbox demo stand?
I will be retaining the pan
donn ·
PM sent
funbug ·
Yes and....no
could you please enlighten?
funbug wrote:
Yes and....no
Yes, I still have the front bumper. No, it is not original or rust free...!
vwdave ·
Hi Glenn,
PM sent re: steering column.
Dave
VW dave:
Column, steering wheel, complete wiring harness (removed from car) and door latches (all with key) $150
hulbyw ·
Is it a klm speedo and working? If so how much are you asking?
beetleboyjeff ·
Do you still have the steering shaft (I need the one with the smaller top for the steering wheel) and possibly the lower shaft as well? I will take the whole lot as you advertised it if that is how you wish to sell it, or just the shafts (that is what I would prefer).
Jeff, car has one-piece steering ckumn as it is a 76 flat-screen, but I may be able to help you with a 'small spline' L-Bug column, PM me or call
Hulby, speedo is good: check link below
http://forums.aussieveedubbers.com/viewtopic.php?tid=81825#pid761397
beetleboyjeff ·
PM sent.
beetleboyjeff wrote:PM sent.
... not here. Call 0411 274 155
funbug ·
Do you still have the ignition lock and door handles? If so, do they have the same key? Definitely interested if that's the case
VWCOOL wrote:VW dave:
...comes with blower unit and everything except tail light pigtails
