Aussieveedubbers · Bugs
Another Tacho Wiring question?
https://forums.aussieveedubbers.com/threads/81730/another-tacho-wiring-question
jjwebb123 ·
Hi Guys.
I got a tacho and need help with wiring.? i did a search and nothing really suits what im looking for. I know one wire connects to your battery,one to your ignition,one to ground, and one i THINK to your coil.Now if this is the case,which side and how do you connect it to the coil.is there a type of fitting to have two wires going to the one source.
let me know.
unless its one of those big 100mph tachos with a shiny light that tells u to change gear or has lots of colour changing LED lights it wont have a connection to the battery
only ignition, ground and signal to the coil which is usually always green and goes the the -ve side of the coil
if you cant see which is negative its the side that has a wire running down to the distributor
jjwebb123 ·
thanks mate,mine is the one with a shift light and fancy lighting.lol so yeah battery.is there a certain way to wire it to the coil,like do i just strip the wire and tire on to that(not that i would).but whats the go,connection wise.?
thanks
