[sa - fs or swap] 71 lowlight for beetle or type 3
https://forums.aussieveedubbers.com/threads/81773/sa-fs-or-swap-71-lowlight-for-beetle-or-type-3
Vespa76 ·
anyone want to swap a beetle for a 71 lowlight?
Second owner, only had the it for 4months (i have a 76 kombi and want a beetle) The Motor is solid and has done a genuine 11318 miles. It starts and runs well. I had it serviced when I first got it and only really replaced the distributor rotor, leads and plugs.
Needs new shocks, new breaks (leaking from cylinder) exhaust gaskets. A bit (term used lightly) of rust repair & panel work
General Body
Reasonable, with a major dent in the passenger rear and a bit of rust. I will document the car as best I can with photos.
More general photos here: http://s600.photobucket.com/albums/tt86/coreydoddphotos/Herman-general/
The back floor is clean and looks like new, there is some rust on the front floor and this will need to be repaired. Small amount of rust on the front window. The 3/4 window is rusted out pretty bad, but I have replacements. Some surface rust in areas.
Close ups of "problem areas" here: http://s600.photobucket.com/albums/tt86/coreydoddphotos/Herman%20-%20Problems/
Interior:
camper interior from another lowlight which is of the right era. I have not securely placed this in yet so no drill marks have yet been made. There is no fridge but everything else.
More Photos Here: http://s600.photobucket.com/albums/tt86/coreydoddphotos/Herman-interior/
Contact details:
Based in SA, Coromandel Valley
corey (at) coreydodd.com
call 0410 122 755
type3disease ·
pm'd
Vespa76 ·
I forgot to add type 3's also, just want something smaller.
