Seller's Name – Lindsay Smith
Suburb / Post Code – East Gresford NSW 2311
Item Description – VW cylinder head disassembly / assembly tool.
Condition – New
What Do I Have?
Well I'm glad you asked.
This is a VW cylinder head disassembly / assembly tool.
This fantastic tool is used to disassemble and then reassembly the old Dak Dak cylinder heads.
If you have ever worked on VW heads with a normal “G” style spring compressor tool you will know that a “G” type of tool “just don’t cut the mustard” on Volkswagen heads.
Most of the time it just wont fit and if you do get one to work you usually end up with a high speed valve lock flying straight up your nose!
With this tool you set the head in it and set the tool over a spring retainer and push down on the handle then pick out the valve locks with long nose pliers (dead set easy as)
A great investment for your VW tool box.
This tool also has the advantage of being able to be folded down on itself for storage and also makes it easy to post.
Works on 1100cc - 1600cc heads
Cylinder head not included for display only!
Will be posted in a package that is about
45 cm long
40 cm wide
10 cm high
And be 4000g
Posted from 2311 N.S.W
Cost $45 + postage let me know your post code and i'll work out the postage cost
Lindsay
yasdnil01 ·
