Longer Wheel Studs For Kombi
https://forums.aussieveedubbers.com/threads/81876/longer-wheel-studs-for-kombi
pod ·
Bought some wheels for my kombi, they come off a T4 ,to make them fit Properly i need some longer wheel Studs and the centre bore needs a tickle for the grease cap(thats the easy part),So my question is where can i buy the longer wheel studs from???
Try http://www.niceproducts.com.au/catalogues/wheel/wheel.php They dont list anything for a Kombi, but they do list a 14mm x 73 mm long stud.
The stock front studs are longer than the rear, so swap those around and if the 73 mm long ones are long enough and have the correct knurl size use them, other than that its the P word as in Porsche.
pod ·
thanks Steve will check them out
Otherwise give Holzl a call
mackaymanx ·
http://cgi.ebay.de/Raendelbolzen-M14-von-40mm-bis-100mm-Laenge_W0QQitemZ230378151484QQcmdZViewItemQQptZRad_Reifenzubeh%C3%B6r?hash=item35a39b9e3c
http://www.csp-shop.de/cgi-bin/cshop2/front/shop_main.cgi?func=det&wkid=97557656736&rub1=Wheels%20%2F%20Brakes&rub2=Wheel%20Stud%2FNuts&artnr=14842a&pn=0&sort=0&all=
http://www.vwparts.net/mm5/merchant.mvc?Screen=CTGY&Store_Code=VWP&Category_Code=WHEELSTUDS
