ENGINE PARTS NOW SOLD
Alll brand new parts I have bought for new engine which I am no longer going ahead with.
AS41 Mag case (machined to 94mm and for fulll flow oil)
CB performance 69mm forged cw crankshaft 8 doweled
Chromoly 13lb flywheel 8 dowel (balanced to crank)
CB perforamnce UNITEC rods
CB performance Los Banditos cylinder Heads (machined 94mm)
Scat C35 Cam kit
Mahle Bearing kit
case fitting kit
case hardware kit
crank fitting kit
end float shims
gasket set
crank seal
bearing dowels
uprated cb gland nut
cam plug
$2500 for everything. If no luck selling may split.
Pm for more info
Ghia67 ·
