[edit] No longer need the carby but still after the manifold and extractors
jacky_moo ·
stoßen!!
bump*
I have some new extractors....will send you a pm.
esevwbits ·
I have a set of these for sale
$130.00
postage to melb $25
jacky_moo ·
hey esevwbits thanks for that but im after some stock style ones ... sorry really should have clarified that
as i currently have and exhaust set up very much the same as that pictured above..
Im after a standard style performance system
jacky_moo ·
Bump Im still after a set of stock style extractors
Like those pictured above!
funbug ·
jacky_moo wrote:Bump Im still after a set of stock style extractors
Try George at Classic Veedub. I got stainless ones off him.
alien8 ·
esevwbits wrote:I have a set of these for sale
$130.00
postage to melb $25
Hey mate ,whats with the two short elbow pipes under the heat riser connections. Never seen that before on a header.
funbug ·
$130.00
postage to melb $25
Connects to the heater boxes and to the foil or plastic pipes from the fan shroud
Get the stainless one
Good for the money
alien8 ·
Bizarre wrote:Get the stainless one
Good for the money
I am using the Empi version of this system atm and I had to flatten one of the lower pipes a little to clear the full flow pump cover. Does the stainless version from George suffer this problem too? I like the system itself but, god, the Empi system is just woeful quallity.
mmmmmmmmmmm..........doubt it would foul
There is about 20??mm between the pump cover and top pipes from 2 and 4
That said i am currently going to a custom built set up
I flanged my connections because it didnt want to seal properly. Dont know if it was the fault of the extractor
I hate all extractors equally for this reason
And ALL exhausts suffer from poor design regarding the heat riser take offs
These ones werent even drilled. Any heat to the manifold is purely conduction
That said - it works ok at stopping incing.
As an extractor - it is not much better than a stock set up
But i like the fact the pea shooters are fixed
As i said - for the money they are ok
Pity you cant buy a stock exhaust in stainless
alien8 ·
I like that this system comes out of the stock cut outs and has good ground clearence.
20mm from stock pump cover to pipe I am pretty sure that would foul my style of full flow cover.(old Burg style) The base on the cover is prob 8-10mm thick plus the outlet barb sticks out another 25-30mm.
I am looking at a stainless hideaway style this time around and like you, get some flanges welded on the J pipes. I bloody hate those doughnut gaskets. Does the stainless system have baffels fitted in the tail pipes?
alien8 wrote:. Does the stainless system have baffels fitted in the tail pipes?
yeah - same as the other one
jacky_moo ·
No longer need a set just going for an OEM muffler .. now to find some trumpets ... FWEEP FWEEP here we come!
