I’m after an indicator stalk and ignition barrel assembly to suit a ’69 squareback as pictured.
I need a complete unit that i can slide onto the steering column and hook up the wiring at the base.
I do not require the actual ignition barrel but ill take it if its already in there.
A couple wires pulled out of the indicator based, i attempted to repair it as you can see but to no avail =/
Does anyone have one, or know a breaker in Sydney that might have one?
Thanks,
Michael
DylanTheDubber ·
looks liek a bug one. maybe a S or L bug one might be usalble ???
GoldCloverLeaf ·
Possibly... can anyone confirm this?
I'll try and ring around on monday, who might have type 3 used parts, should i try vintage veedub at compsie?
tdegens ·
i got a later type 3 unit with the washer and removed the washer part. Had to cut a bit to make it fit. And solder the wires on. Took quite a while to get it finished
Tazz ·
That seems to be a later version.
Early type 3's 62-63 had the ignition barrel ova the top.
i think up to about late 68 they had this style.
