Does anyone have a spare indicator/ignition column unit to suit a "69 type 3? (pic inside)
https://forums.aussieveedubbers.com/threads/82026/does-anyone-have-a-spare-indicatorignition-column-unit-to-suit-a-69-type-3-p
GoldCloverLeaf ·
I tried this in the parts wanted section but not much luck...
I’m after an indicator stalk and ignition barrel assembly to suit a ’69 squareback as pictured.
I need a complete unit that i can slide onto the steering column and hook up the wiring at the base.
I do not require the actual ignition barrel but ill take it if its already in there... just name your price.
A couple wires pulled out of the indicator based, i attempted to repair it as you can see but to no avail =/
Does anyone have one, or know a breaker in Sydney that might have one?
Thanks,
Michael
1500S ·
What section isn't working?? Indicator or ignition??
DH
GoldCloverLeaf ·
The indicator unit... or more specifically the plastic base where the wries attach to. A couple of the wires have pulled out of it and its not really possible to do a proper repair here (i attempted this already).
And its not really viable just replacing the indicator unit, as the wires run under the metal column to a connector at the base, which would be difficult to remove without causing more damage... so yes a really need a complete unit as pictured, with or without the ignition barrel.
GoldCloverLeaf ·
Ok... not to worry anymore, surprisingly vintage veedub have these new on the shelf (just the indicator unit though), so i will attempt to rewire it and run the wires in a different location.
Mike
