oil cooler tester
https://forums.aussieveedubbers.com/threads/82027/oil-cooler-tester
yasdnil01 ·
Seller's Name – Lindsay Smith
Suburb / Post Code – East Gresford NSW 2311
Item Description – oil filler nut tool
Condition – New
Cost - $7 + postage
Email - almetal@iinet.net.au
What Do I have today ?
Well I'm glad you asked !
This is a vw oil cooler pressure tester to check for leaks and faulty oil coolers. It fits both types of oil cooler on dak dak donks. The dog house type on the 1600cc engines and the older internal cooler found on 1100cc 1200cc engines.
You simply bolt this handy item up to your oil cooler and add up to a max of 35 psi air pressure from your air supply and spray with soapy water or place in a bucket of water to check for leaks
This tool can also been used for flushing and then reverse flushing out the oil cooler, you just remove both the air valves and flush with a solvent like kero. What I do was to make up a pressure pot that holds few liters of kero. connect up a hose from the bottom of the pressure pot to one side of this tool mounted on the oil cooler and then pressurize the kero pot to 30psi... you do this one way and then back the other way several times ......you will be amazed all the crud that comes out !
You could even bolt this handy item to the engine case and flush it out also; you just bolt it to the case where the oil cooler goes and flush away!
VW oil coolers not included!
For display only
Will come in a tough postal bag
Posted from 2311 N.S.W
Remember to check out my other items up for sale.
You never know what you will find!
yasdnil01 ·
Item Description – crankshaft holding jig
Condition – New
Cost - $30 + postage
This is a VW Volkswagen crankshaft holding jig
Just the thing for holding the 1200 - 1600cc crankshafts
Makes putting on the con rod / bearings / gear and dizzy drive so much easer, saves you having to chasing your crankshaft all around the work shop floor
Just mount this stout little tool to your work bench, mount your crankshaft with your own gland nut and bob’s ya auntys lover!
Just the thing for the VW tinkers or the almost complete VW workshop
Will come in a package
23cm long
25 cm wide
10 cm high
And be 5500 g
