I've tried searching here, and not much to go on.
My horn would work intermittently, and sometimes go off in a turn.
I pulled the horn ring off and kept the hardware in the order of disassembly. I checked grounds, wiring and the horn itself, and all checked out OK.
I found the teflon washers under the 3 screws were worn quite thin and at the edges. I replaced the washers.
After reassembly, the horn doesn't work at all when the horn ring is pressed. When I short a screw driver between the horn ring and each screw individually, the horn blows. When I short the screw driver between the steering wheel nut and horn ring, the horn blows.
Anyone have any ideas? It's a '65 Beetle, stock standard, 6V.
65standard ·
