Seller's Name – Lindsay Smith
Suburb / Post Code – East Gresford NSW 2311
Item Description – Case boring / flycutter
Condition – New
Cost - $435 + postage
Email - almetal@bravo.net.au
What Do I have today ?
Well I'm glad you asked !
I have a brand new SCAT VW Head and Case boring / flycutter assembly tool for sale. It is brand new from SCAT USA .
It is brand new and never been used.
It works on 1200cc to 1600cc engines
This kit comes with everything you'll need to machine your case and heads in your own shop a real
Versatile and inexpensive tool
Special Professional tool designed to bore cases & heads for oversize cylinders & pistons or flycut heads for increased compression, or just clean up the sealing surface of the head
Tool may be used with mill, drill press,or hand drill
Ring base of tool housing eliminates necessity of milling head surfaces to use tool
356-T6 Aircraft Quality Aluminum Housing machined to exacting tolerances with a Greasel fitting to lubricate the 1-1/2" diameter precision ground steel shaft
3/4" x 1-1/4" Steel Tool Holder & Centering Block are precision machined to insure accuracy
Precision machined tool steel cutter
Let me know if you have any questions!
Go on !
You know you want it !!!
yasdnil01 ·
