oil pump puller
https://forums.aussieveedubbers.com/threads/82148/oil-pump-puller
yasdnil01 ·
Seller's Name – Lindsay Smith
Suburb / Post Code – East Gresford NSW 2311
Item Description – oil pump puller
Condition – New
Cost - $15 + postage
Email - almetal@iinet.net.au
What Do I have today ?
Well I'm glad you asked !
This is a VW oil pump puller.
It’s used for removing pesky pumps that are stuck in the housing of air cooled vee dubs donks.
This is a great tool to have around and worth its weight in gold when you need one.
HOT TIP: remember to always loosen a few of the crankcase bolts closest to the oil pump, the one above & the one below the oil pump before attempting to extract the pump.
This tool comes with 2 of the “T” extractors, small one is for 1100-1200cc engine oil pumps with the smaller oil ways and the other is for the larger oil pumps used on 1300-1600cc engines.
You just take off the oil pump cover, remove the 2 pump gears, insert the correct "T " into the in and out oil holes of the pump body then place the large C bracket on the threaded "T" in a vertical position and then just wind the nut and this will remove the oil pump body from the crank case
Will be posted in a tough bag
And be 500g
fish26 ·
Hey Lindsay where about is East Gresford.
yasdnil01 ·
howdy,
East Gresford is half way between Singleton and Dungog, 1 hour and 45 minutes from Newcastle... in the Hunter Valley
funbug ·
Would recommend this tool. Bought one from Lindsay and it was well made, cheap and worked a treat.
yasdnil01 ·
Yep it's fantastic tool all right !
saves ya pulling ya hair out when trying to get a stuck oil pumps out
it soon get ya back on the road and doing dub doughnuts again ....lol 👍
