Is there anyway of lengthening a throttle cable?
The cable in my beetle is about 20mm too short but I don't really want to take the old one out unless I really have to
Mike
colonel mustard ·
does it exit out the fan shroud??? if yes, its possible...
OK so why is it short broken , different linkage or ????
Mike ·
Its not broken, its standard length.
The carbie I'm using has the same style connector just the linkage is slightly further away.
yeah so wot carbie is it ???
Mike ·
its a 28/36 dcd weber
OK so thats why its short
u can get some 1/8 rod and 2 joiners to lengthen to get ot the kinkage
Mike ·
Sorry to sound like a complete moron, but what sort of joiners do I need to use?
vwo60 ·
i think holley make a extension piece that attaches to the standard cable end with a grub screw, you could try a carbie specialist to see if they could get one for you, i had one that i used on a holley bug spray years ago.
As vwo60 above but I'd also try a vw shop. It's a cable extender, one simple fitting, a grub screw and a longer shaft, prolly about 40mm overall.
