I must admit that since buying my daughter her '69 Bug I have learnt a heap. This forum has been invaluable to me and I'd like to thank everyone that has given freely of their advise and experience.
Though..there are a few things I'd like to clarify if anyone can please.
Is the later model 1300 motor (70 onwards) actually a 1600 block with 1300 pistons and barrels fitted to 'detune' it for reliability? Some have mentioned that the late model 1300 (AR******* engine numbered) Twin Port motors are amongst the best motors to 'hot up/rebuild for performance motoring..is this a fair comment and why not just fit a 1600 motor instead of doing up a 1300???
My daughter's bug has a Rear Suspension Compensating or Overload Torsion bar fitted...am I to rightly assume that since this was fitted to 1500s only then her car was originally a 1500?
What are the advantages of the '009' distributor that is fitted to it?
What is meant to be fitted between the heater boxs and the sump ? as there are a couple of tabs and bare mounting brackets that I can see.
Would actually fitting a flexible tube from the air intake of the air filter to the hole in the lower tinware beside the crank pully be beneficial?
Since my 16 yr "L" plate daughter is still at school and not flush with money...what would be some reasonably cheap add-ons that would add to it's reliability and performance that a bloke like me who is pretty handy with the spanners could do?
Oh...I'm still chasing a second hand ignition switch to replace the one I believe is giving us some starting problems.
Gazza265 ·
