wiring
https://forums.aussieveedubbers.com/threads/82196/wiring
clinker42 ·
Hi Guys
What wires go up the back of a VW
Earth
Indicators
Brake Light
Tail light
Reverse light
Number Plate light
Oil Sender
Coil
Battery charge wire
Alternator Excite wire
Electric choke
Starter Solonoid wire
Have I forgotten any wires.
if you mean the wires in the main loom then theres no earth
Also the number plate light jumps off on side parking light
theres also no reverse light or choke wire in the loom, they just piggy back off the coil
clinker42 ·
No earth in the main loom, so the tail light, indicator and brake light earth is just a short run and earths onto the body in the engine bay.
So how does the reverse lights work, they are earthed onto the tail light assy along with the indicators and tail brake. So they must recieve power from a switch somewhere, they cant be onto the coil or they will have power all the time and need to be earthed seperrately.
The reverse light is a hot tap off the +ve on the coil - through the reverseing switch - through the lights and to earth
clinker42 ·
So power comes from the coil, of to the reverse switch, then to the lights and earth.
Thanks Guys, will make some changes now
