Seller's Name – Lindsay Smith
Suburb / Post Code – East Gresford NSW 2311
Item Description – 36mm axle nut tool
Condition – New
Cost - $12 + postage
Email - almetal@iinet.net.au
What Do I Have?
Well I'm glad you asked.
This is a 36mm rear axle nut removal tool
This tool is used to remove the stubborn 36mm axle nut that holds the rear brake drums on the old Dak Dak
After you remove your wheel and the axle nut split pin you place this tool on the axle nut and then with a few heavy wacks with a hammer the nut will come off (easy as).
Also has a ½’’ square drive hole for use with a bar ½’’ square drive bar.
Every VW home mechanic should have one.
Just contact me with your post code and I can work out the postage cost
Will come in a package that is
25cm long
12 cm wide
2 cm high
And be 1500g
Posted from 2311 N.S.W
I take bank deposit, paypal, postal money orders as payments
Remember to check out my other items up for auction.
You never know what you will find!
yasdnil01 ·
