AJPerkins wrote:When it comes to covering the percentage of the tyre how much is that?
Cheers AJ
Glad to help, mate! The only place where I can find mention of the rules for fenders at the moment is in the "National Guidelines for the Construction and Modification of Street Rods in Australia", which doesn't technically apply. If we assume that the rules are the same as for street rods then the minimum fender coverage is the entire width of the tread surface, covering at least one third of the tyre's circumference and extending at least 15 degrees below the axle centreline. I would use this as a guide, but the rules for modified production vehicles are often quite different to the rules for Street Rods, as the Australian Street Rod Federation has fought long and hard to get the Street Rod regs to the state they are today. Technically if you wanted to fight hard enough for it, you could claim that the VW Type 1 was originally manufactured before 1948 and that all Beetles are therefore eligible to be registered as Street Rods, but I wouldn't go there! Street rod rego would give you permission for 10" wide rims though, and a tube frame chassis if you really felt excited!
