Fuel Pump Rod
https://forums.aussieveedubbers.com/threads/82254/fuel-pump-rod
clinker42 ·
Hi Guys
Does anyone know the measurement the fuel pump rod should sit above the spacer block when its rod is in the down position.
Thanks Trev
Generator or alternator fuel pump, they are different. Gen style is 13mm above on up stroke going by memory.
clinker42 ·
Hi Matt
It has an alternator but I have no idea what fuel pump it is. I presume George gave me a Alt fuel pump. So at full stroke it should be about 13mm up, do you know what the alternator one should be.
Thanks again
Trev
I've never had factory spec for alt except it's much shorter and nearly flush with bakerlite stand on bottom stroke. I do have a pushrod length for the alt pump but in the workshop. I didn't post before as it's not precise info. The alt fuel pump is leaning on an angle away from the alt/gen stand. Surely someone here has better info and a pic of both types.
going from memory the alt rod is 100mm and the gen is 106mm
108mm for genny pumps apperently
