FS Random Bits and Pieces Front Discs for a 68- On bug. [NSW]
https://forums.aussieveedubbers.com/threads/82276/fs-random-bits-and-pieces-front-discs-for-a-68-on-bug-nsw
71-BEETLE-SEDAN ·
I have got some random bits laying around that i dont need.
Two running boards off a 64. Both have some rust but also have beed treated so no more can form and can easily be bogged up and sprayed or rubber mats fitted.
I have a washer bottle off a 71 standard. Comes with the bottle a long hose to the switch and the short hose to the wheel as well as the two clips that hold it in the spare wheel.
I have the piece of metal off the top of the rear seat as well as the piece from the bottom, both are in great shape and are black. These came from a 71.
I have the bracket that holds the base of the back seat in place for a 64. Its grey and needs a bit of sprucing up but is very solid.
Also have the horn button out of the 71 its in preety alright shape.
I have alot of spare hubcaps for 4/130 Wheels. There are some in good nic while others have been sprayed different colours and are in bad shape.
I have some rubbers off the pedals, not to bad, good for a daily.
Got a boot lock but it has one screw hole, dunno whay its off but has no key but opens easily.
Got some tailight brakets dunno what thereoff but they have reverse lights and are the skinnier version of the tombstone tailights.
Front sway bar off a ball joint bug. With rubbers, rubbers are preety hard but will be alright, clips inc.
Front Disc Brakes off a ball joint bug, very rusty but still useable. And lots of meat, with all fitting stuff except calipers and hoeses. Will sell with disc brake spindles. Front spindles, no drop, for discs. Will suit ball joint bug, and will combine with discs.
Torsion arms off a ball joint bug, Look in good nic.
Steering box, condition unknown, but spins easy by hand. 68-On Bug.
Offer me a price for whatever parts you want. Postage is fine for smaller objects but bigger ones will need to be picked up.
Im located in Mittagong NSW 2575.
Best contact method is by PM or text to 0407432787.
My Name is Josh
71-BEETLE-SEDAN ·
Bump pics added
hulbyw ·
Please see PM re headlight surrounds
71-BEETLE-SEDAN ·
pm replied
headlight surronds sold
more stuff bump
you can bin the points, thats only one half of them
single screw decklid latch is from a 4 vent decklid and the tail light housings are 72 but will fit 68-72 for anyone wanting reverselights
71-BEETLE-SEDAN ·
will scarp points tommoro,
Forgot to add steering box spins very freely and is complete with the shortest tie rod.
71-BEETLE-SEDAN ·
New gear up. Bumpity
71-BEETLE-SEDAN ·
Bump, The money from these is going towards rims and brakes.
71-BEETLE-SEDAN ·
Bump
71-BEETLE-SEDAN ·
Bump,
Brakes will be machined this week. Still have lots of meat.
Sway Bar PM Replied to.
71-BEETLE-SEDAN ·
Bump, Going to clean up brakes now and sway bar still up for grabs.
71-BEETLE-SEDAN ·
Bump, brakes now machined and all shiney stored in dry place so no more surface rust can form. Front beam up for grabs too.
71-BEETLE-SEDAN ·
Bump
71-BEETLE-SEDAN ·
Now 8 4/130 rims for sale 4 with good tyres and 4 with okay firestones, major camber wear.
Discs are no longer for sale.
Front beam is also now available
71-BEETLE-SEDAN ·
bump
Pumba ·
Is it a bare beam with no extras???
71-BEETLE-SEDAN ·
At the moment its a bare beam with no extras but if you want any extras like leaves or torsion arms then they can come with it.
Its all here except for the brakes now.
Pumba ·
What $$$ do you want for the bare beam ???
71-BEETLE-SEDAN ·
For the beam, $75 and i could get it to you on the long weekend thats coming up.
Its been flap disced to remove old paint and rust, there was a crack in one of the shock mounts in one skin butit has beedn welded and the ground down smooth and its now black.
Pumba ·
No worrys thanks anyway cheers shane.
71-BEETLE-SEDAN ·
Bump,
Now also a 175 michellin xzx tyre, no use at all. Still has writing on the tread from when bought. Can come with rim or with for $150 either way.
71-BEETLE-SEDAN ·
BUMP
