Anyone any good with petrol generators
https://forums.aussieveedubbers.com/threads/82293/anyone-any-good-with-petrol-generators
Beerboy 路
I have bought one of those crappy hurricane 2 stroke generators off ebay. Its was still in the box and not been run for a while. I have filled with gas and can smell petrol at the spark plug but cannot get a spark. Pretty well stumped as there is no decent documentation and I have no idea if it has a battery or coil pack. any one any ideas apart from put it back on ebay 馃槀
waveman1500 路
It will have a coil/magneto thing next to the flywheel somewhere, check that it's all okay. Is it switched on? Tried a new plug? Cheap two-stroke engines can be very hard to start sometimes, but a new or cleaned, dry plug usually helps.
Beerboy 路
yes turned on and turns over pretty well, just will not fire. plug looks brand new but probably not a bad place to start.
should it have a battery?
greedy53 路
as above and also remove the plug and earth it on the head or any where you can earth it than give it a tug and see if there is spark
Beerboy 路
greedy53 wrote:as above and also remove the plug and earth it on the head or any where you can earth it than give it a tug and see if there is spark
thats what I tried to come to the conclusion no spark
could smell petrol with plug out
donn 路
I had the same problem with my sons small GMC generator, ended up bypasing the small rocker switch that turns the motor off, turned out that it wasn't doing its job and was permanantly turned off.
Beerboy 路
donn wrote:I had the same problem with my sons small GMC generator, ended up bypasing the small rocker switch that turns the motor off, turned out that it wasn't doing its job and was permanantly turned off.
that sounds like a good place to start mate as everything else looks like new, and is silly enough to be the reason.
will give it a go tonight
waveman1500 路
Remember that an open circuit = ignition on though! If you just solder the two pieces of wire together you will never get it going!
Beerboy 路
now I am confused, so I need to put a replacement switch in there
68AutoBug 路
Beerboy wrote:now I am confused, so I need to put a replacement switch in there
Yes
to turn the engine OFF....
Beerboy 路
ok great thanks. makes sense :-)
Beerboy 路
thanks donn I swapped out the switch and it started put the old switch back in and it started so must have been a dodgy connection. thanks for that I am well pleased. didn't want another large brick
donn 路
cool that it worked for you, I fixed my problem by simply doing away with the swith altogether, just touched the wires to stop it
